Theres normally a access panel under the back seat with a fuel pump under there, just pop the fuel pump out pop in a hose, suck on it a little, get dizzy and hey presto!
or just jack the car up and bash a screwdriver in the tank
Just feed a hose a good way in, then cover the end and pull out, until you draw petrol right the way up the hose out the tank, then make the end lower than the tank and let go and it should siphon it out.
