Hi, I am new to this forum, but i just wanted some advice on watercooling this setup.
Its a Server, it is using the new Intel 5400 Series of Xeon processors with a 1333mhz FSB and 12mb cache.
Each processor is a Quad core 2.88Ghz and there are 2 of these, so in total 8 cores, The system will also be used primarily for virtualisation so it will be under quite a lot of load constantly which is why i have decided to go for a watercooling solution, due to noise and heat. Any sugestions on an ideal setup?.. the socket type is LGA771.
Thanks
Thanks
