It was intended to be more of a demonstration rather than a final piece as I was in the middle of getting ready for college.
Unless, of course, you mean that you've given it a blast yourself and it still doesn't work, in that case, I have some watching material for you courtesy of the great Bert Monroy - http://revision3.com/pixelperfect/reflections
Think about where you would put a mirror if this object were real, the kind of reflection you are trying to achieve is artificial so you are not going to be able to do it without distorting the original in some way.
As a final note, if you want to make a decent "true" reflection of the house then you should re-draw the house. The true reflection would let you see under the roof, you also might not be able to see the chimney etc..
