Remember you can't link to competitors although I have a feeling that this will go that way so be careful.
My laptop keyboard has a ribbon cable which sits into the system board and is held via a small white clamp, they call it (apparently) a cable-lock, which, I'm sure you'll agree, returns the usual security locks associated with laptops, etc.
This clamp thing has lost one of its ends and no longer grips the cable causing me frustrating issues with my keyboard.
They can only be pence (maybe a pound or two max), problem is, I can't find one.
Winner gets very little apart from the satisfaction of being the best OcUK searcher ever!
Here is an image. That thing lifts up by a mm or so to allow the cable to sit in, then pushes down and holds it in place.
