"friendly fire"
May have.
Quite disappointed that the Times have jumped into the scaremongering wagon..
The fact is that it is scary that these blood transfusions could have gone ahead without the proper screening. Imagine if you'd just been told you need an AIDS test, what would be going through your mind?
They were emergency transfusions and they may have died without them. Its nice to have a mind to have things going through.
Doesn't alter the fact that this blood should have been certified as clean.
What part of "emergency" makes you think they had the time to do that ?
Better to try pumping certified clean blood into a corpse right ?
They didn't pump the blood directly out of the donor into the patient you know. The blood was given some time ago and should have been screened before being released for use. If there was a problem with this blood then some other stocks would have been used. This is a case of procedures not being followed correctly, not a House-style medical ethics drama.They didn't pump the blood directly out of the donor into the patient you know. The blood was given some time ago and should have been screened before being released for use. If there was a problem with this blood then some other stocks would have been used. This is a case of procedures not being followed correctly, not a House-style medical ethics drama.
I understand that the blood was taken from other soldiers some days before it was used presumably in the knowledge that stocks were low, and that there was not time or even the means to check it normally.
Unless you have information to the contrary ?
