This spec ok for MATX gaming rig ?
JSW
JSW
19 Oct 2002
Staffs
Samsung SH-S203D 20x DVD±RW SATA Dual Layer ReWriter (Black) - OEM £14.99
(£17.61) £14.99
(£17.61)
OCZ StealthXStream 600w Silent SLI Ready ATX2 Power Supply £44.99
(£52.86) £44.99
(£52.86)
Intel Core 2 Duo E2180 "LGA775 Conroe" 2.00GHz (800FSB) - Retail £49.99
(£58.74) £49.99
(£58.74)
Gigabyte GA-G33M-DS2R Micro ATX (Socket 775) PCI-Express DDR2 Motherboard £57.99
(£68.14) £57.99
(£68.14)
Western Digital Caviar SE16 250GB SATA-II 16MB Cache - OEM (WD2500AAKS) £37.99
(£44.64) £37.99
(£44.64)
GeIL 2GB (2x1GB) PC2-6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) £29.99
(£35.24) £29.99
(£35.24)
HIS ATI Radeon HD 3870 XT ICEQ3 512MB GDDR4 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
and this case: http://www.thermaltake.com/product/Chassis/miniCase/lanboxLite/vf6000bws.asp
Cheers
I could push the budget only reason I chose ATI is I have had ATI cards in all my pc's since the Radeon64 to the 1950pro so been faithfull to the brand for some years.
Would it be worth waiting for the 3870x2 ?
Also would this MB be any more use as would like to oc the cpu as much as possible
Asus P5K-VM Micro ATX (Socket 775) PCI-Express DDR2 Motherboard
Thanks
The gigabyte board is superb, if you are overclocking, it has the 1:1 dividers for the 1066/1333 cpu's. With the E2xxx you will need (1066) ram for o/c as the memory dividers start at 266 for the E2xxx.
Would OCUK PC8500 ram be ok or would I need to pay a bit more and get the crucial ballistix or which ?
Cheers
Thanks
I think you would still need a crossfire board to run the 3870X2 and i seriously doubt if it would fit in a M-ATX case anyway. Come to that i expect that it will not fit in a lot of ATX cases. It's huge. Sticking with one brand just because you always have had them is just misguided loyalty. Get whatever is the best that you can afford at the time. For an extra £15 you can't go wrong with a 8800GT.
Also could anyone tell me which cpu HSF will fit in the lanbox with the DS2R mobo.
Thanks
Thanks got the version with the led's just had doubts as wether it would fit as the northbridge heatsink is very tall.
Have since seen another member using it on the S2 mobo so should be fine.
Thanks
Ok got everything except memory and Graphics card
Zalman CNPS8700-LED CPU Cooler
I borrowed my sons Geil 2gb dual channel kit and used the onboard graphics so I could install XP Pro and the motherboard drivers and left it at that as he wanted his mem back lol
Now I'm thinking I will get the EVGA Crysis edition 8800GTS but still unsure which memory to get?
Lol, not even just 1 stick. What happened to sharing is...
If you can, it will be nice to post up some build/complete pics :)
