Ok basically just writing up the notes i took when doing my manoeuvres earlier in my driving lesson. This is what i have came up with:
Reversing around a corner.
1. Pull up to the curb leaving 1-2ft gap between the curb and the car.
2. Stop and put the handbrake on and look around. (especially the blind spot).
3. Once safe to move reverse until you can see the curb starting to bend in the rear left corner mirror. Stop and check around you.
4. When you start to move do a ¾ turn on the wheel quickly.
5. Keep reversing around the corner but make sure you watch in the left door mirror (while occasionally looking behind you) and watch the gap between the curb correcting when according. Stop every so often checking around the vehicle.
6. Once the curb enter the middle of the rear window STOP. Look around.
7. Reverse while looking behind you and keeping and even gap between you and the curb (use left wing mirror).
8. Stop handbrake.
Parallel parking.
1. Pull along side the car in front of the space you want to park in and leave a 2-3ft gap between you and the car.
2. Before moving off observe around the car. Then reverse until you can see the end/edge of the car to your left in your rear left window. Stop Observe.
3. When the car begins to move, one full left turn and reverse until the rear wheel arch in left door mirror touches the curb. Stop and observe.
4. Turn the wheel back to the right when moving and reverse until your left door mirror covers the cars rear light. Stop observe.
5. When car begins moving another quick right turn. Stop observe.
6. Once the car is straight on with the car in front then stop and observe.
7. When start moving turn the wheel one left turn and continue reversing back looking out of the rear window and left door mirror.
8. Stop handbrake.
Does this sound ok?
I have my test on Tuesday so i want to revise these two as these ones are the ones i have most trouble with.
EDIT. Im learning in a Corsa 1.2 4 door btw.
Ryan
8. Stop handbrake.
Parallel parking.
8. Stop handbrake.
Does this sound ok?
Ryan
