I really do need help.
I'm using Office 2007, PDF995 and Adobe's PDF converter.
Bear in mind I've managed to take a screenshot of my desktop and copied that to Word 2007 and converted that nicely to a PDF format as a sort of test.
However...
I have created various line charts in Excel 2007 and have one column chart with a little drop shadow and gradient effects. The line charts can be converted without hassle to PDF format from either Office or Photoshop using either the save to PDF functions or print to PDF.
However, it all goes up in smoke when I try and convert the column chart to PDF. I create charts in Excel then transfer them to Word 2007 so all charts are in one document.
Basically the chart is just under A4 size and I want it converted to a PDF format as my work place doesn't have Office 2007 and they would like it in PDF format if possible. The chart however, when saved gets all kind of artifacts from either a white line in the chart series, blurry text or very pixelated text.
I'm tearing my hair out at this and would have thought it would be relatively easy to convert such chart to PDF format?
The chart is also 987 x647 pixels.
I also try to paste this chart into Photoshop with the PPI at 600, but when I select 'Print' the chart image becomes like one square inch in size on the A4 paper. Do I need to make the chart huge in Excel and then copy it to Photoshop?
Please help. Thanks
However...
Please help. Thanks
