$loths progress thread.
13 Aug 2004
England
I've started back after having some time off and thought I would post a progress thread to keep track of how i'm doing and for people to give their input.
The original 3 day split I used this week was this:
back/triceps
deadlifts 4x6
front pulldowns (alt with pull ups monthly) 3x8
Rows 3x8 (alt with t-bar monthly)
dips 3x12
Chest/biceps
W/U - Bench 1x15
bench 3x8 *
incline bench 3x8
cable fly's 3x8
hammer curls 3x12
legs/shoulders
W/U - Squats 1x 15
squats 3x12
leg press 3x8
SLDL 3x8
lateral raise/shrugs 3x8
db shoulder press 3x8.
7/1/08
Back/Tri's
Deadlifts 60kg, 80kg, 90kg, 100kg x6
Front pull down - (setting)6x12, 8x10, 10x8
Rows - 40kg, 40kg, 50kg x8
Dips - 12,10
Tri Pushdowns 30kgx12, 40kgx12.
Thoughts: Not a fan of dips for triceps, so I'll be sticking with pushdowns for a while (then give dips another go). Also, find out how much that bar weighs.
10/1/08
Chest/ bi's.
DB flat bench - 15kgx15 (Warm up). 15kg, 15kg, 16.5kg x8
Cable flyes - 20kg x8, 20kg x8, 25kgx3, 20kgx5
(lever) Incline Bench - 20kg x12, 30kgx8, 35kg x8
Hammer curls - 10kg, 10kg, 11.5kg x8
Thoughts: I didn't feel like I could go straight from flat to incline bench, so I went straight to the flyes and then used the assisted incline bench (plate loaded on a pivot system).
12/1/08
Legs/ shoulders.
Squats - 50kgx15 (Warm up). 60kgx8, 70kgx8, 70kgx6
Vert leg press - 60kg, 70kg, 80kg x8
Leg curl - (setting)5, 7, 8x12
Smith B.T.N press - 20kg, 20kg, 30kg x12
DB Shrugs - 16.5kg, 17.5kg, 20kg x8
Thoughts: I didn't feel much on my shoulders from this day, chest was still DOM'ing. Thinking of changing the shoulder exercises to DB shoulder press/Mil press + Lat raises, moving the shrugs to back day as a last exercise. Find out how much that bar weighs (oly bar).
I didn't feel safe doing SLDL after those, will give them a shot this week.
proper oly bar with metal ends? 20kg.
some have plastic ones and are about 17kg iirc
each bar in my gym is weighed actually. a lot of them are 21kg. i just assume them to be 20kg for purpose of deciding what weight i'm lifitng though.
Well I've said it before and I'll say it again. There are more productive ways to spend time in the gym than P/P/L or any other form of split that hits each bodypart once a week. If cutting then twice a week is fine but for hypertrophy 3x times a week is better, brutal but better. Just my £0.02.
Hitting muscles twice a week as opposed to once. Actually working by weeks is a bit daft for bodybuilding, I'd say more like once every 4-5 days is going to yeild better results than once every 7 days.
I know what you're saying Chong, but I know with $loth it's a case of training when he can.
I train a 2 days on 1 day off 2 days on 1 day off repeating day 1 every 7th day which has always worked fantastically well for me.
I don't think it's daft, unless it's your life is bodybuilding it's doing what you can, when you can.
4/1/08 - Back/Tri's
Deadlift - 90kgx6, 100kgx6, 110kgx3+100kgx3, 60x8.
Front pulldown - No.7x12, 8x12, 10x6+9x4.
Tri Pushdowns 3x12 - 35,40,45.
(wide grip)T-Bar row - 30kgx12, 35kgx10, 35kgx8.
Notes - Didn't take into account the bar weight so I was suprised when I counted the deadlift, lowered the weight after a few reps of 110 as my form was going.
17/1/08 - Chest/Biceps
Flat DB bench - 15kgx15, 16.5kgx8, 17.5kgx8, 18.5kgx7.
Cable flyes - 20x8, 20x8, 25x7.
(lever) Incline bench - 20kgx8, 20kgx2+15x6.
Hammer curls - 3x8 10kg.
Notes - Left shoulder started aching on the last set of cable flyes, I think I made have strained it from how I was grabbing the pulley.
19/1/08 - Legs/shoulders.
Squats - 50kgx15, 60kgx8, 60kgx8, 70kgx8.
(45%)Leg press - 70kg, 90kg, 110kg x8, 130kgx6
Lying leg curl - 3x12 - No.6,7,8.
Standing calf raise - 2x12 - No.8.
DB shoulder press - 15kgx8,15kgx8, 17.5kgx6.
DB Lateral raise - 3x8 - 10kg.
Notes - Felt that I could pound out some more reps at a higher weight on the leg press so I really went for it. Shoulder was feeling fine today so did some work with dumbells, try mil press next week.
