This weekend's spannering and antics
Man of Honour
Man of Honour
3 May 2004
SILENCE!
I haven't wielded a spanner in anger since a few weeks before Christmas. This weekend I decided to hit the garage harder than ever before to make up for some lost time. I'm going to be losing my flat and garage in a few months so I need both cars running, spares reduced to a minimum and a slim down on tools.
Saturday morning I bolted the alternator back on the Pop and fired it up after standing for nearly a month now. Started up after a little cranking and ran as normal and the alternator appeared to be working, so we loaded it up with the dead spare engine, a gearbox, a couple of clutches, starter motor, dead dynamo, some old cardboard boxes, some scrap metal and a load of old tins of paint. Ideally this should have gone to the scrap man because I probably could have got a few quid for the metal but time was slim so it was down the tip with it. My mate chucked the gearbox from above his head straight through the front of a nice glass fronted microwave oven and then the two of us threw the engine on top of a lawnmower that made a satisfying crunch. Then the other bits were all aimed at some empty metal drums and we generally made a nuisance of ourselves between people trying to tell us nice old car etc. Bizarrely old paint just goes in 'general waste' despite being 2K and in my opinion it's a bit toxic to be just throwing about so we put that upright and in view in case anyone thought otherwise.
Then it was shoot back to have a look at the brakes on my mate's 2003 S Type Jag. It's got aftermarket brakes which have some badly designed clips on the pads that turn in and rub on the disc. This makes them squeal and they just start to wear away, so you'd eventually have no retaining clip and the pad would end up rattling around. So we modified them and problem solved, but not before I managed to stab myself in the eyebrow with my needle nose pliers pulling them off with all my strength. Hey they're a big target on my face, don't ask.
Next it was head over to another mate with starting problems with his MG Midget. It was last run in 1998 but was all rebuilt etc ready to go. So he got sparks and it turns over but no fuel coming up and he can't suck it up the pipe. I took the pump off and the two valves were stuck shut so a prod and suck later and it was working again, back on and pumping like a pornstar. Now we just couldn't get any fuel to go through the carbs so I reckon the jets must be blocked up. I squirted some fuel down the pots and it fired so I then aimed the fuel line in one carb and it ran but revved right up to the top where the throttle cable had hooked itself up and yanked the throttle wide open. Opps. It also sprayed me down with petrol in a gush not unlike one of those squirting porn sites even with my thumb over the end as hard as I could. Look it up if you haven't seen it, kinda strange. So that was mate number 2 happy too.
Sunday I'd promised a local RR member I'd show him the basics of welding so loaded the Pop up with my MIG welder, grinder and some tools and popped round the corner. Had an eyeball at his '69 Mini which looked to be in pretty good shape despite him thinking it was knackered. It's been quite heavily restored at some point but it all looked like it had been done to a high standard. The front footwells had been stick welded in and I think that was what was putting him off because the welds are very proud and thick compared to MIG but they looked fine to me. I just recommended he stripped the paint back so he could have a better look at them. So out with some scrap metal and the pointy zappy sparky sticky metal together machine and we got on with a bit of practice welding and I showed him how to do some basic repairs by welding a small crack which had propogated in one of my front wings. Not from driving the car so hard it twists honest officer. He did quite well with it so I think when his Snap On machine turns up he's going to have fun there.
So I'm satisfied mechanically which means I don't need to get angry and beat the missus or any of that stuff that happens when you're frustrated because you can't get out to the garage :)
Anyone else do any spannering this week?
Did the work needed doing to mine...in a professional manor ofcourse :p
Where I went into the other car...upon closer inspection it was shown that the front passenger side of the car had all been "nudged" back slightly...the metal bar behind the front bumper needed bending back into place therefore Dad's way of doing this was....standing on the bumper whilst bouncing on it whilst on the phone :p
he got off it, we tried fitting the headlight and indicator and both slotted in asif nothing had happened :D The front bumper is very very slightly out of line but to do this properly it will need to come off etc. which we didn't have time for, and it'll need to come off in the future anyway to be sprayed :)
Looking at the car now, at a first glance you can't instantly tell it was in an accident, result :)
I did :cool:
I had a knocking going on at the back of the Jeep whilst off roading & remember my passenger asking about it & me telling him not to worry about it :p Then later Ed reckoned my rear shocks were gone as my back was bouncing so much, I just said Meh & got on with the day. Saturday i had a nose about underneath & it turns out the bar that gives me my lift & connects both shocks to the body was disconnected rendering my rear shocks useless :D
New washers & bolts sorted it a few eye fulls of grit & about an hour laid on the floor spannering. The back end feels much better now :D
This off roading malarkey means Constant spannering is needed, Suits me though i like it even when it is cold.
Didn't do too much - tightened up the alternator belt a bit on the Prelude where it's stretched slightly in the last 6 months/9k miles use, and adjusted the main beam headlights to where they should be pointing, not illuminating the tops of the trees, like they have been for the last 6 months...
I havn't done anything major lately :(
However.. I will be removing the down pipe off my HDi today and welding a piece of pipe where the cat used to be ;)
I ain't done jack (barring uni workshop antics on the Nissan). Still trying to find something to spanner on!
Might be that Polara........Do like that :)
Fitted a CD changer, changed engine ECU and rigged up a spare coil. Did a full service last weekend.
Fitted new Osram bulbs to headlights, front Diadem indicators and also sidelights. Made a huge difference, but headlights aren't calibrated... so pointing at the floor slightly.
To just change the bulbs, I had to remove the whole front bumper and grill... 10 mins job my ****!
So worked on that most of Saturday, fixed my clock too. However, when I took the battery out, I wiped my Pioneer head unit's memory. It now goes bright blue full screen every 30 seconds for a short period, then off again. VERY distracting at nighttime.... so that is my next "to fix" job. :D
My Vespa was a bit like that. You had to take the front of the headstock off, but to do that you had to take the back off but to do that you had to take the glovebox off but to do that you had to take the little horn cover off the front of the bike then you found you had to take the footplates off to get the glovebox off but to do that you had to take the rear side trims off...
Aaaagh I've had to strip the bike to its bare metal chassis to change the headlight bulb!!! Who designs these things? :rolleyes: :rolleyes: :rolleyes:
It's to get you to take it to a dealer so that they can quote you about £60 to change them
Painted wiper arms and replaced my bonnet badge, it's nice and red now instead of pink:o
So that's 2 bolts i've spannered over the whole weekend, poor show!
Still haven't quite finished the engine swap on my MG ZS. I really only need to put the crank pulley and injection system back on now and was planning on doing it on Saturday. Unfortunately I was on call and I got called out at 10am just as I was donning overalls and the callout ended up lasting until 5:30pm. :mad:
Will be doing the odd bit this week and then finish it off this weekend as I need to jack it up to do some of the remaining jobs like tighten up the suspension ball joints.
Once the MG is running again I'll turn my attention back to my mk1 Escort which I've bought a new electronic ignition kit for (including new dizzy). Also got a list of jobs on the BMW to do before I trade it in. Too many cars, not enough time!
Which is ridiculous really, bulbs are supposed to be able to be changed at the roadside in emergencies even in the dark. Fitting bulbs these days on a lot of cars is a big piece of work so you've got no chance in that situationn. :o
