- 9 May 2007
as title says
which one should i get? antec 900 is £20 more but then i can spend it on more silent 120mm fans for the cm690 as it fits 7x 120mm fans... but the antec has an 200mm fan... ummmmm
if i was to spend the £20 on a couple of silent 120mm fans for the cm690 would preformance be as good as antec900 case?
edit: noise is not much of a factor so the speeds with be on high on antec900. and i will drill a few holes for cable management.
which one should i get? antec 900 is £20 more but then i can spend it on more silent 120mm fans for the cm690 as it fits 7x 120mm fans... but the antec has an 200mm fan... ummmmmif i was to spend the £20 on a couple of silent 120mm fans for the cm690 would preformance be as good as antec900 case?
