PPD for a Q6600?
hmm I get about 4400-4500 PPD using 2 instances of windows SMP clients with my Q6600 @ 3.56ghz under Vista 64
Not meaning to question that but how??:eek::eek:
I get a fraction over 3k ppd with a Q6600 @ 3.15ghz running 24/7 and 2 win smp clients. i can't imagine that another 400mhz can produce a jump of 1500ppd
What is your average frame time?
For comparison, I'm running 2 WinSMP clients on one of my Q6600s at stock (the useless clocking one) while I'm at home and am getting about 18-18.5 mins per frame for a PPD of 2,700-2,800.
This would mean booyaka getting an extra 300-400 PPD for 750MHz and gurusan getting an extra 1700 PPD for 1160MHz. Something's not right somewhere - either booyaka's rig isn't performing as it should or gurusan's is punching well above it's weight.
booyaka. I think there's either something wrong with your setup or you're using the rig for other purposes or something. Looks like gurusan's PPD is about right.
I've set up 2 WinSMP clients on my other Q6600 @ 3.0GHz and it's taking 13.5 mins per frame, giving me a total PPD of about 3750. I've just tweaked the memory timings and will see if that edges it up any (got the RAM running at 833MHz at 4-4-4-12 @2.1V - not bad for cheapo Geil stuff).
The second rig is on a fresh Windows install with very little else on it, which may make a slight difference but not that much. I decided to switch because all my quads are getting on Linux SMP just now are the P306* WUs which were giving me a total PPD of about 2500 running 2 clients - I'm now getting 1 1/2 times that running WinSMP clients (always seem to get P2653s on Win SMP). I won't be switching back until the weedy WUs are finished.
hmmm - well my ram is 4-4-4-12 @ 2.2v running 1:1 with FSB @350.
It is used also for some gaming etc etc but not heavily - maybe 90mins a day or so.
-- f@h number 1 --
Avg. Time / Frame : 15mn 13s - 1665.54 ppd
-- f@h number 2 --
Avg. Time / Frame : 17mn 57s - 1411.92 ppd
One is running slightly slower than the other ( running from 2 seperate drives) but nothing else major running during the nighttime or day time when i'm at work etc.
Also killed off a few un-needed processes in windows etc see if that helps.
weird.
Very.
Tightening the timings has knocked off about 10s per frame so far - giving me an extra 50 PPD or so - up to 3800 now.
Your RAM is running slower than mine but that should be cancelled out by your extra 150MHz CPU speed. Maybe your gaming is having a bigger impact than you think :confused:
Well I dunno...but this is according to FAH
Looks good to me mate. Seems to correlate with my experience. I get 1000 PPD more from a 600MHz OC with tighter timings which would seem to suggest that your 520MHz extra with the faster RAM would easily get you the extra 600PPD over mine.
Nice OC btw :)
running my Q6600 @ 3780, RAM @ 4-4-4-12 with 2 WIN SMP Clients, each client is pushing a unit out on average at 11 mins 51 seconds
Edit:
Well enough units done now, recons my PPD is: Client 1: 2539 Client 2: 2573
anyways late time for bed :)
Edit 2:
Last super sneaky edit before bed (Turned a load of rubbish off!):
-- F@H WIN SMP #0 --
Avg. Time / Frame : 10mn 19s
-- F@H WIN SMP #1 --
Avg. Time / Frame : 10mn 08s
thanks - will have a look at this later today.
Also does having a higher FSB, i.e 400x 8 help rather than 352x9 (both being roughly 3.2ghz)???
I always prefer higher FSB clocks because they help out benchmarks...I'd imagine they would help folding a bit as well, but by how much I couldn't tell you.
would imagine that where a process has a lot of communication between CPU <-> RAM that the high FSB would produce "faster speeds" if this is noticable in the "real world" I have no idea
Also I would imagine this effect would be greater on a quadcore where the CPU is "doing more" and potentially using more RAM
-- f@h number 1 --
-- f@h number 2 --
weird.
well optimiser installed and wahey - what a difference!!!:p:p
-- C:\ --
Min. Time / Frame : 12mn 34s - 2016.76 ppd
Avg. Time / Frame : 13mn 22s - 1896.06 ppd
Cur. Time / Frame : 12mn 37s - 2008.77 ppd
R3F. Time / Frame : 12mn 37s - 2008.77 ppd
Eff. Time / Frame : 14mn 30s - 1747.86 ppd
-- F:\ --
Min. Time / Frame : 12mn 30s - 2027.52 ppd
Avg. Time / Frame : 12mn 35s - 2014.09 ppd
Cur. Time / Frame : 12mn 35s - 2014.09 ppd
R3F. Time / Frame : 12mn 35s - 2014.09 ppd
Eff. Time / Frame : 12mn 35s - 2014.09 ppd
amazing effect on my system now!:D:D:D:D
