- 10 Mar 2004
There's clearly something amiss with those scores though.
Three cards apparently offer a relatively small advantage over two in Crysis ,at present that is, but they should not run at half the speed of two in any scenario, except perhaps at lower resolutions.
Are you only seeing this anomaly in Crysis, or is the pattern repeated with other games?
What resolution are you at, what AA/AF?
http://www.bit-tech.net/hardware/2007/12/13/nvidia_3-way_sli_on_nforce_680i_preview/5
http://pcper.com/article.php?aid=495&type=expert&pid=12 (they only tested at 1280x1024 and also found 2 cards faster than 3)
http://www.anandtech.com/video/showdoc.aspx?i=3183&p=4
Only the last of the three reviews above used a 780i motherboard (the other two a 680i), though it appears they all used the 169.18 beta drivers, you could give them a try.
