Want a new case
19 Jan 2006
Guernsey
Hey guys,
I'm after a new case and want some opinions on what to get.
I want a smaller case than what I currently have, I have a stacker at the moment, and I just want a Midi case I think....
I've got rid of all my water cooling and am back to air, but it has left a gaping hole in the top of my case as I did have a triple 120mm radiator.
I would prefer black with silver accents rather than silver with black bits. I want it to be quite stylish and not garish. I have 4HDD's and one optical drive, I don't intend to add any more hard drives but would like room for an extra on just in case. I want 120mm fans only as I have a load of high quality ones.
Heres the previous case for reference to size.
http://i49.photobucket.com/albums/f289/Rusteh101/IMG_19.jpg
http://i49.photobucket.com/albums/f289/Rusteh101/IMG_10.jpg
The floppy bays can double as internal 3.5" bays. If you have a budget on the higher end You could go for something like a V1000 or even a PC-101.
There's also the every-popular Antec P182.
I just got the Coolermaster CM 690 this morning it looks sleek and straight foreward i particular like the two fans on top i think its better than some with a bigbig one on top!
[/IMG]
[/IMG]
[/IMG]
Antec Solo. It may have 2x92mm fans holders at the front instead of the 120mm you are after but you can pick up a couple of quiet 92mm fans for £5. It is also a high quality case and allows cable routing etc. I couldn't be more happy with mine!
Only thing that puts me off the 690 is my experience with my current case the Centurion 341-342 or whatever it is :p Since th mesh front likes to gather a lot of dust sometimes, its just not ideal
Its the same mesh stuff as the stacker, everyonece in a while I clean them, it's not a big problem, but it does look ugly, maybe enough to put me off the 690..... Hmmmmmm
