**CALL OF DUTY 4 MODERN WARFARE**
You just completed :ACT II 2.2.3 'One Shot, One Kill'
You have still to do :ACT II 2.2.4 'Heat' + 2.2.5 'The Sins of the Father' + 2.3 ACT III
2.3.1 'Ultimatum' + 2.3.2 'All In' + 2.3.3 'No Fighting In The War Room' + 2.3.4 'Game Over' then finally ACT IIII 2.4 Epilogue
2.4.1 'Mile High Club'
Guys,
I removed COD4 from my Vista machine but backed up the folder and saved games. I installed XP and installed the game again but the folder is not the same and I dont have a clue where to put the saved games.
Anyone with ideas so I dont have to start all over again.
Regards.
Just Google it, there will be plenty of peeps with same Q.
Run it in XP, get 1 Save then Search for the extentsion of the SAVE (same as your ones) and XP will list them and Open Location :)
This is where my save game files are from XP.
C:\Program Files\Activision\Call of Duty 4 - Modern Warfare\players\profiles\perox\save
Guys, can you help?
I have a 22" CRT and when i put COD4 inot 1600x1200 it doesn't fill the screen properly. It is as if the image is adjusted to dar to the right and is cutting the very edge of the image of whereas there is plenty of space on the left.
Just wondering if anyone else has this?
errr isn't 22" 1680x1050 as optimal Res, so 1600x1200 it's not sure what to do with it, I could be wrong but stick in 1680x1050.
***Ignore me I'm an idiot*** :p
He's using a 22" CRT not a Widescreen TFT, so its native res might be 1600x1200
CRT's don't have a native resolution. However you have to balance out the maximum refresh in that resolution, to slow down involved...plus in Windows don't want text to be too small.
Some of the weapons are too good in COD :D
Whats the best Assault rifle to be using? atm im using an SMG with a Red Dot with Martyrdom its the 3rd of 4th one down and its pretty good, im also using the Double tap on it and its a pretty good gun..
Its amazing how in this game doubletap is increased rate of fire, in real life double tap is 2 succesive single shots.
It depends what you like, I'm a hardcore nut and thus love the G3 as it is accurate as you like and on hardcore one good shot is all you need. I also love the M16 and for closer range assaulting i have a silenced G36c.
If you prefer the spray and pray weapons a little more try the carbine.
Does anyone know of an easy way of obtaining or creating a time-demo to be able to re-run the same benchmarks time and time again like on older games
I want to compare various drivers against identical in game play
Thanks
