windows mediaplayer Q
Caporegime
30 Jun 2007
Wales
Is there any way/program that would make the frame/playpause/close/max/min buttons disappear like the divx web player when in windowed mode? so its just the video no frame etc?
media player classic can do this
when, you can simply click on the screen and drag it about, pressing space to pause it.. awesome player
pressing CTRL + 0 (and some of the numbers from 1-9) removes the border and the controls, there about about 5 different views you can have..
plus, it opens super quickly
on the ver. of mpc i have, just press 1-->3 for varying levels of gui-less-ness
oh, didn't know that :)
the way i use it then..
press 1 on its own, then press ctrl + 1, ctrl + 5, gives you time bar, and seek bar
ctrl + 7 gives you the playlist ;) -you can drag that out of the window too, and if mpc is set to be 'always on top' the playlist is too :)
