Yet more memory deals for you!!!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
We have good stocks secured at pricing that was before price increase of the last few days so are bringin you some more special.
Crucial Ballistix 2GB (2x1GB) DDR2 PC2-5300C3 667MHz Dual Channel Kit (BL2KIT12864AA663)
The Ballistix line is specifically built for performance enthusiasts who want to push the performance envelope without worrying about data loss or corruption, mysterious intermittent errors and display problems, or worse — the dreaded BSOD! The Ballistix line of high-performance memory modules features advanced speed grades, low latencies, and integrated aluminum heat spreaders.
- Module Size: 2GB kit (1GBx2)
- Package: 240-pin DIMM
- Feature: DDR2 PC2-5300
- DIMM Type: UNBUFFERED
- Speed: DDR2-667
- Voltage: 2.2V
- Memory Timings: CL=3
- Warranty: Lifetime
- For warranty support and RMA replacement call Crucial Direct on 0800 013 0330 or 01355 586 100 who will replace your faulty memory within 48 hours.
Previously sold for £47.99+VAT (£56.39 Inc. VAT)
Price: £37.99+VAT (£44.64 Inc. VAT) (£11.75 Saving!!)
BUY NOW!!
Corsair 4GB DDR2 XMS2 PC2-6400C5 TwinX (2x2GB)
The Twin2X4096-6400C5 G is a 4096MByte matched pair of DDR2 SDRAM DIMMs. This part delivers outstanding performance in the latest generation of dual-channel DDR2-based motherboards. It has been tested extensively in multiple DDR2 motherboards to ensure compatibility and performance at its rated speed. This memory has been verified to operate at 800MHz at the low latencies of 5-5-5-12. Corsair’s line of 4GB memory kits are designed for PCs featuring 64-bit operating systems. Please note: Installing 4GB onto PCs with 32-bit operating systems is not advised since 32-bit operating systems do not support 4GB of system memory.
Previously sold for £64.99+VAT (£76.36 Inc. VAT)
Price: £59.99+VAT (£70.49 Inc. VAT) (£5.88 Saving!!)
BUY NOW!!
Corsair 2GB DDR2 XMS2-6400C4 TwinX (2x1GB)
The Twin2X2048-6400C4 is a 2048 MByte matched pair of DDR2 SDRAM DIMMs. This part delivers outstanding performance in the latest generation of dual-channel DDR2-based motherboards. It has been tested extensively in multiple DDR2 motherboards to ensure compatibility and performance at its rated speed. This memory has been verified to operate at 800MHz at the low latencies of 4-4-4-12. The Twin2X2048-6400C4 comes with Enhanced Performance Profiles (EPP), the open standard for performance module SPD’s jointly developed by Corsair and NVIDIA. EPP SPD’s on Corsair modules allow users to automatically configure EPP enabled motherboards with aggressive memory performance settings, for maximum memory and system performance.
Previously sold for £35.99+VAT (£42.29 Inc. VAT)
Price: £32.99+VAT (£38.76 Inc. VAT) (£3.53 Saving!!)
BUY NOW!!
Crucial Ballistix 2GB (2x1GB) DDR2 PC2-6400C4 800MHz Dual Channel Kit (BL2KIT12864AA804)
- Feature: DDR2 PC2-6400
- Speed: DDR2-800
- Voltage: 2.2V
- Memory Timings: CL=4
Previously sold for £49.99+VAT (£58.74 Inc. VAT)
Price: £41.99+VAT (£49.34 Inc. VAT) (£9.40 Saving!!)
BUY NOW!!
G.Skill 4GB DDR2 PK PC2-6400C4 (2x2GB) CAS4 Dual Channel Kit (F2-6400CL4D-4GBPK)
G.Skill, the well known extreme performance provider, today announces the new naming rule. It helps the users can distinguish the product specification through the new model name. G.Skill also launches the new DDR2-800 CL4-4-4-12 4GB memory kit, F2-6400CL4D-4GBPK, with the new naming rule. G.Skill 4GB Kits support both Intel and AMD platforms.
- Package : 4096MB kit (2x2GB) dual channel pack
- CAS Latency : 4-4-4-12 (PC2-6400)
- Test Voltage : 2.0-2.1 V
- Speed : DDR2 800MHz (PC2-6400)
- Type : 240-pin DDR2
- Error Checking : Non-ECC
- Registered/Unbuffered : Unbuffered
- Quality Control : Comprehensive rigorously tested in pair at dual channel environment
- Warranty : Lifetime
Previously sold for £74.99+VAT (£88.11 Inc. VAT)
Price: £64.99+VAT (£76.36 Inc. VAT) (£11.75 Saving!!)
BUY NOW!!
Crucial Ballistix 2GB (2x1GB) DDR2 PC2-8500C5 1066MHz Dual Channel Kit (BL2KIT12864AA1065)
- Feature: DDR2 PC2-8500
- Speed: DDR2-1066
- Voltage: 2.2V
- Memory Timings: CL=5
BUY NOW!!
Crucial Ballistix Tracer 2GB (2x1GB) DDR2 PC2-8500C5 1066MHz Dual Channel Kit (BL2KIT12864AL1065)
What is Ballistix Tracer memory? Ballistix Tracer memory is specifically built for performance enthusiasts and case modders who want to push the performance envelope while adding flash appeal to their boxes. The Ballistix line of high-performance memory modules features advanced speed grades, low latencies, and integrated aluminum heat spreaders. Ballistix Tracer memory features a black PCB, black integrated heat spreaders, and one or two rows of eight "chasing" red and green LEDs atop the module, circulating in a random pattern based on memory utilization. A custom-designed circuit relays bus activity to the LEDs, allowing them to accurately reflect usage of each memory module. In addition, eight blue ground effects LEDs emit a constant glow near the pins.
- Speed: DDR2-1066
- Voltage: 2.2V
- With LED's
Previously sold for £69.99+VAT (£82.24 Inc. VAT)
Price: £64.99+VAT (£76.36 Inc. VAT) (£5.88 Saving!!)
BUY NOW!!
G.Skill 4GB DDR2 PQ PC2-8000C5 (2x2GB) CAS5 Dual Channel Kit (F2-8000CL5D-4GBPQ)
G.Skill, the well known extreme performance provider, today announces the new naming rule. It helps the users can distinguish the product specification through the new model name. G.Skill also launches the new DDR2-1000 CL5-5-5-15 4GB memory kit, F2-8000CL5D-4GBPQ, with the new naming rule. G.Skill 4GB Kits support both Intel and AMD platforms.
- CAS Latency : 5-5-5-15 (PC2-8000)
- Speed : DDR2 1000MHz (PC2-8000)
Previously sold for £84.99+VAT (£99.86 Inc. VAT)
Price: £69.99+VAT (£82.24 Inc. VAT) (£17.63 Saving!!)
BUY NOW!!
OcUK 2GB (2x1GB) DDR2 PC2-8500C5 1066MHz Dual Channel Kit
OcUK is proud to announced DDR2 1066MHz, PC6400 800MHz supports CAS 5-5-5-15 with 1GB and 2GB Dual Channel Kits. These modules are sourced from Elixir to ensure maximum compatibility, reliability and performance.
- PC8500 1066MHz CAS 5-5-5-15
- 240pin, Non-ECC, Un-buffered DDR2 SDRAM DIMM
- 6 Layers Ultra Low Noises Shielded PCB
- 1yr Warranty
- 2.0V-2.3V Power Supply
Previously sold for £39.99+VAT (£46.99 Inc. VAT)
Price: £34.99+VAT (£41.11 Inc. VAT) (£5.88 Saving!!)
BUY NOW!!
Crucial 2GB (2x1GB) DDR2 PC2-5300C5 200-Pin SODIMM Dual Channel Kit (CT2KIT12864AC667)
These SODIMMs allow users to maximize memory bandwidth and minimize performance bottlenecks to deliver a superior user experience. Built to Crucial's legendary quality and reliability standards, each module is tested to ensure maximum compatibility. Each Mac Memory module is individually tested and certified to run at 667MHz and be compatible with Apple products.
- Module Size: 2GB Kit (1GBx2)
- Package: 200-Pin SODIMM
- DIMM Type: Unbuffered
- Speed: DDR2-667
- Voltage: 1.8V
Previously sold for £29.99+VAT (£35.24 Inc. VAT)
Price: £23.99+VAT (£28.19 Inc. VAT) (£7.05 Saving!!)
BUY NOW!!
These are absolutely amazing deals, especially considering memory prices have hit a bottom and are now and have already increased due to the ever decreasing dollar rate due to a strengthening US economy which makes these deals particular special and an ideal time to buy.
Good price on the GSkill PC8000 PQ, same as what I paid for it a couple of weeks back, it had been creeping upto the £100 mark before todays offer.
They overclock like lightning bolts people. :)
i have the tracer versions (leds) but from what i have gathered there the same Interconnects ;)
Proof.
taken these picture when testing them 3 days ago, aint finished yet ;)
Jesus christ stop it or I'm gunna have to grab a copy of vista 64bit and 4gb of ballistix! :p
Man memory is dirt cheap now. Nice one gibbo :D
Proof.
You got loads to go yet, got exactly the same ram at 1250mhz 8hr Orthos stable:D
Show that proof, got a picture ?
no way in hell you got that speed with T1 command rate.
I could easy get 1250+ in T2 command rate but i wouldnt run those speeds on Nforce boards they dont like it.
they love T1 command rate with as tight as possible timeings and as high mhz as you can get before you start to sacrifice timeings.
high mhz= AMDs
Tight Timings = Intel
got my corsair 2x1GB 6400C4 March 2006, it cost me £230. Got me exactly the same kit 2 weeks ago £40!!!! LOL!!!
4x1GB 4-4-4-12-2T @ 800MHz on my striker extreme with Vista x64 SWEET!
NOW THE X-FI ISSUE WHICH HAS CAUSED ME TO SELL MY FATAL1TY CARD!
There's a cracking ram deal in the clearance section, 1GB of Geil DDR2 6400C5 for £11 or 512MB of Corsair Value DDR2 4200 for £2.34
Would be ideal for a second rig. Only 1 left though so I don't think it will be there long.
high mhz= AMDs
Didnt see the 1T, and you are right yes. Would have no chance of getting up there @ 1T.
Jesus, the deal on the Gskill lasted what about 20hours???
You started off by saying - "We have good stocks secured at pricing that was before price increase"
Then they go back up nearly 25quid!!!:o
Agreed...I was planning on buyng it right now...it's wasn't even 24 hours before he changed the price:confused::confused::confused::confused::confused:
The least he could have done is kept those prices for a full day.
