trial account gives u full acces to everything, you should be able to whisper...
if not type '/w (persons name)' then your message... without the brackets
for example "/w blowmytotem can i have an invite please?" - then hit enter, and it will show up in pink text
hope this helps! its quite tricky to get used to! i picked up on it quite quickly cos i used to play Diablo and Starcraft by blizzard, so the commands are very similar!
Is there a way to change it? I guessing its in Interface options?
