Evening All,
Yesterday I decided to attack the my 306 HDi, with the intention of removing the cat,
Firstly I jacked the car up on one side with two jacks and a massive piece of wood under the car just incase the jacks failed.
I got all my tools and scrambled under the beasty.. Only to get a bit confused as to how the Front Pipe came off, I knew how to remove the exhaust clamps but had never removed anything from the front section of an exhaust before... Fortunately one of the mechanics off 306.net was on MSN and guided me through the process ( Dead Easy )
Exhaust is back on the car now and I find it is a lot more responsive and nicer to drive..
Pics below for you all to enjoy
Above You can see my exhaust section, I welded a Brace onto the pipe so that the exhaust would stay the same shape as before and not cause me problems when refitted.
Above is a close up of the cat I set out to remove,
Above, The attack was complete. One nasty cat removed
Above, New piece of pipe welded in place, Fortunately my dads friend is a Mechanic so I drove down the road and he let me have a piece out of his scrap pile.
Above, Close up shot of the welds.. Not the best in the world but I ground them down and welded over them again on a hotter heat just to be sure that there was a proper seal.
Above, Finally the exhaust was ready to refit.. I thought.. Until I remembered that Black gloss paint will probably melt once it gets hot.. So Before I went to bed I removed all the black paint and put some " Galvafroid " on to keep the rust away
Now before anyone shouts " Oi that won't pass its MOT " I've been told by many people with this Done that It does pass and MOT because they test the emissions, and the Cat on this car does sod all.. ( Legal on Some Diesels ? Illegal on Petrols )
EDIT - Pics Rehosted due to imageshack taking ages to load
John.
John.
