I'm currently looking to buy a laptop. I have been looking at the Dell M1330 and the MacBook. The Dell thrashes the MacBook spec wise (£ for £) but I think I want to try OSX (as I don't want to move to Vista and I have grown tired of the continuously amount of looking after thats needed with XP). I hear that apples just work and that sounds good to me
Few questions that I've got tho, before I make the plunge.
1) I am going to be using the laptop for web development and some photography work. Is a macbook suited for doing web development? I am currently working on drupal and use vmware in xp to run virtual LAMP setups so that i can test my designs etc. Are there any limitations of OSX that you can think of that I am going to constantly need to use paralells or bootcamp to run XP so that I can do whats needed for this type of development?
2) In XP I generally use Opera for my browsing, however some 'poorly' written websites don't render correctly or worse just don't work at all. I then need to revert straight back to IE to get them to work. Does Safari have the same problems meaning I 'occasionally' will need to use paralells to get to IE so that I can view the webpage correctly?
3) Are bootcamp and paralells free? and will i need both?
4) Is 'all' the hardware in the macbooks now supported in XP (both in parallels and bootcamp)? i remember reading somewhere that the webcams don't work, but that was a long time ago and I don't remember which apple it was on.
5) At home I have a Windows MCE machine that I use as my file server. Its formatted in NTFS and it stores all my music, video, pictures etc. Am I going to get problems using this as my files store? will keeping the files on this NTFS windows pc restrict some of the functionality that the macbook and OSX programs can offer me?
6) Will the lack of a dedicated gfx card cause me problems for image manipulation? presume not... and I've got a xbox 360 for games.
7) Are both the memory and harddisks user upgradable? and how much memory would you recommend?
8) How long does the battery really last on the macbooks between charges?
9) I know there is never a good time to buy, but is now a bad time for any reason? When are 45nm penryns likely to come to macbooks? Also are there any deals on? like free ipods with HE discount etc.
Cheers.
Cheers.
