I noticed this with mine a couple of weeks back. I've got mine hooked up to a fan controller, so it starts beeping the second the pump shuts off.
I think i've narrowed it down to the wire coming out of the pump, or the wires going into the molex. Basically, try and secure them and keep them in the same place. Wiggling them around a little will usually get the pump started again, or just go straight for the power switch if you want.
If it continues or becomes a problem for me, I'll be getting it replaced/repairs w/e, guess he should just keep a close eye on it and do the same
