well ive just ordered the game, always said i was neveer going to play a subscripion game, but i cxant stay off the 10 day triallol
Ok - So...I'm now lvl 6 and have gone back to my Hunter trainer. I can now pay to get certain skills, but I don't know what to get?! Can anyone help?
Also - I'm in the middle of a quest which I cant seem to do (although I am getting the WoW Battle chest today which contains the WoW guide. Will that have a step-by-step way to completing quests?)
Basically I have to recover some shinning coin from a cave not far from where you start off as an Orc Hunter, but I can't find it in there. I have explored most of the cave, but I have reached a point where there is some kind of dark magician bloke on a platform which I cannot reach by jumping. I can fire arrows at him but he can dodge every single one of them!
Anyone know what I'm on about? Lol
It also tells me that I cannot use chain mail yet
Chain comes at level 40- it'll appear as a buyable skill from your trainer when you get there.
Arcane shot and SS are 2 of your main abilities so defo use them. As soon as you get 10 do the taming quest from the trainer so you get a pet
As for your cave problems, interior quests can often be problematic to newcomers. This is because there are often lots of monsters closely packed together with patrols. Additionally they respawn at twice the speed of monsters in outdoor locations, which can mean they are popping up behind you as quick as you can kill them if you don't move fast.
yeah its always best to run back toyour body and ressurect... also after level 10 you get 'ressurection sickness' which basically prevents you from doing anything usefull for like 10 minutes!.. not good!
so yes! go get your body![]()
Dean, what char you playing? Shout ingame if you have a problem, and if someones in the locale theyll give you a hand. Just looking at a couple of points you made.
Firstly quests. Get this addon - Lightheaded - it will help enormously with quests. Whenever you have one, user comments will tell you what you need to do to complete the quest and if you click on the blue coordinates, an arrow will appear showing you where the mobs/questgiver is. Incredibly useful. There are a few other addons I consider essential, such as auctioneer and fubar, but I will leave that up to you. You should really think about class specific addons, they make life a lot easier.
As for selling stuff, any vendor will buy the contents of your backpack. When you have the vendor screen open, right click on the thing you want to sell. Auctioneer helps as it gives you an idea of what each item is worth. At the low levels you mostly collect junk, when you start getting greens you can sell those in AH. Cash is always a problem in WoW until you know what youre doing, but you dont need to really buyanything until youre up in the mid-20s as youll be levelling so fast you'll outgrow anything you buy quickly.
