Radeon HD 3670 - When?
16 Jun 2006
Looks like the HD 2600 replacement is due any time now. I have seen the 23rd Jan being banded as the release date. It should be ideal for HTPC applications as it will run cooler and will be easier to implement passive cooling.
Any idea when these will be available to buy at OcUK?
if your talking about the 3870x2 there is a thread for it although I know other cards are being released the same time.
yep they are available from wednesday
No the OP is correct. There is newer HD3--- series coming and might be on Wednesday with the X2.
why are you disagreeing with me I said they are being released the same day as the x2 which is wednesday. :o
You said if you are talking about the X2 which he wasn't. How am I to know if you are informed about the lower end of the HD3--- series? :confused:.
he said the 2900 replacement but never actually stated which version of the 3x series. so I stated if he was referring to the 3870X2 we have a thread he can read up on it, if he is refering to any other of the 3x series - they are also due out the same time as the 3870X2.
LMAO. Look at the title!!!!. Then read the first sentence.
Radeon HD3670
Sorry about this Breeza. Just a little bit confusion here but Wednesday is the day that it either comes out or there will be a lot more detail about it at least.
I apologise. I never read the bit with the other cards :o oops.
Free hit? :D.
dont bother with 3680, the 3x series isnt as good as the nvidia range unless you look at the 3870X2 which is out wednesday. the rest of the cards arent as good and are just budget cards imho. alright for the price but your not gonna get much out of them.
He said it is for a HTPC which would make it perfect.
I'm hoping it's power consumption is somewhere around that of the 2400Pro. The 2600Pro isn't much higher but every little will help for a HTPC build.
I wander if the new 2400 equivalent will have the new UVD with enough oomph to power H.264 decoding properly? That would be perfect!
thinking of putting A 3450.
its low power quiete and has hardware decodoing of HD stuff. <correcT?
anyone wana offer any advice at 45 quid they a bargin for the use i have planned.
