Just reformatted a PC and its sooo slow
25 Jul 2004
I have just installed a brand new hard drive in a PC, installed windows and upgraded the RAM to 1GB. But for some reason the PC is unbelievably slow.
Also, even though it has 1GB of RAM, XP says it only has 256MB.
Would this have anything to do with their being no chipset drivers being installed yet?
Thanks
Thanks
Some more details would be handy ie. motherboard ,ram, the type and number of sticks.
might be a corruprted installation of windows. As far as i nkow the chipset drivers are only essential when overclocking? could be wrong there. I remember someone saying taht somewhere though.
I have tried finding the make and model of the mobo, but with no luck.
The best I can give you is the PC is a Dell Dimension 3000 with an Pentium 4 3.2GHz CPU. I have put a single 1GB stick of Crucial RAM into the system (PC3200 184-pin).
possibly go into your bios and see what it says about your ram? - and it probably says the m/b name there somewhere too, or maybe on the boot screen?
I've just gone into the BIOS, and strangely, the BIOS is reporting 1GB of ram installed.
Also, there are no details of the board manufacturer. It just gives the BIOS version of A02.
always a good place to start - id fully format the drive too if i were you, make sure u back everything u wanna keep up first.
The drive which the OS is installed on is a brand new one. It was formatted and partitioned before windows was installed - so I'll see how the updates go.
Have you tried to do any thing with the old hard drive to see what's wrong with it. Just in case it was a virus or maybe a motherboard or memory problem that made it go down.
I haven't done anything with it. The PC belongs to my two nephews who have had admin rights on the PC for the last 12 months, so theyve practically installed, downloaded and done pretty much what they wanted - and it doesnt help that they never shut it down properly, just cut the power.
I'd run memtest and try that old hard drive in again to make sure that was the problem and not the motherboard or ram .
Edit: It was the CMOS battery :D
Thanks for all your suggestions guys, it was very much appreciated.
Thanks
Phil
