Ordered my new budget lens
Caporegime
8 Sep 2006
On Ocuk
Decided this over the Canon 75-300mm and Tamron AF 70-300mm F/4-5.6 Di LD macro 1:2
Sigma 70-300mm 70-300 f4-5.6 APO Macro Canon fit
To be delivered wednesday!
This is a picture I took with it.
Can anyone explain why the bokeh (is that what it is called?) is hexagonal rather than just a blur?
(SORRY FOR THE SLIGHT THREAD HIJACK BUT I HAVE BEEN MEANING TO ASK THIS FOR A WHILE)
Because it will be using less aperture blades. This means that when you stop down, the hole remaining (The actual aperture) will be a hexagonal shape. The more blades the lens uses the more circular the hole becomes and the more natural and 'creamy' the bokeh becomes. Its not the only factor in the appearance of the bokeh, but its an important one.
For example, this one uses only 7 blades and you can see how hexagonal the aperture is becoming when stopped down(Many lenses use slightly curved blades to help a bit, but you get the idea);
Great explanation. Thanks. Do more expensive lenses generally have more aperture blades?
Sort of (e.g. Canon's cheapest lens - the 50mm f/1.8 - has 5) but after a point, there are other issues about having more aperture blades when constructing the lens and even Canon's L range of lenses only have 8. The quality of the bokeh depends on the glass etc too.
err, my hexagons only have 6 sides. 7 sides would make it a septagon, 8 an octagon.. the clue's in the name.
The explanation though is broadly correct as far as I understand it.
Funny you should mention it. There's something about this in either Professional photographer or Amateur photographer this week.
Not that I've been skiving in work and reading them. Ahem :D
