S-IPS panels (from a desktop display point of view) are commonly considered to be a little behind some VA based panels for movie playback, but this is really subjective. Some sites like BeHardware commonly site movie 'noise' as an issue here, and while you can spot some artefacts (esp on compressed sources), it's not really an issue in practice if you're watching from a sensible viewing distance. S-IPS does offer the widest viewing angles in the market, and does not suffer from the acute contrast shift that you can spot on VA matrices as you move off-centre. I guess the main issue with using IPS panels for movies, and this links with your second point, is that black depth is often quite poor on IPS panels.
If you get a screen with dynamic contrast ratio, this can be handy for viewing movies, and helps get over some of the restrictions of IPS for black levels. In my experienece, black depth is often quite poor on IPS screens sadly. What Fish99 says above is useful as well, and he's right to an extent when he says that a 800:1 contrast ratio TN Film panel may not offer any better black depth than an 800:1 IPS panel. However, you need to bare in mind that the specified brightness value impacts this figure as well, so brightness value divided by contrast ratio figure = black depth. So technically, two 800:1 specced screens could vary.
Also bare in mind that these are often very lose figures and cant always be relied on. black depth is very good on modern TN Film panels (
Iiyama E2202WSV and
Samsung SM245B for instance) and can offer some very admirable performance in terms of black depth and contrast ratio. VA panels can be even better as well, the
Samsung 971P springs to mind for instance. In practice, IPS panels can be quite poor in black levels, and for movies, or viewing content in darkened rooms, it can cause an issue. Might not be a problem to many users, but you can certainly get better black depth from other panel technologies on the whole.
