Permabanned
- 22 Aug 2004
Before anyone starts, work commitments mean mornings must be spent by the phone, so walking outside, cycling etc is not an option.
So i've decided weight training isnt gonna shift as much weight as i need, at least not while maintaining the right diet. So im taking the plunge on something to do low intensity pre breakfast cardio, the best kind! Thing is i dont see the point in blowing £500 on a half decent treadmill with motorised incline and all that gubbins just for a gentle hours walking every morning.
Instead im plumping for :
Star Shaper BT-3130DH-C Motorized Treadmill
http://image.******.com/UK/P0131552_C0000264_P0000000.jpg
Get fit with this fantastic entry level affordable treadmill. The key features of this model are its 2.2 hp peak and 1.0 hp continuous motor which provides a top speed of 8 mph and offers manually adjustable levels of incline. The running deck (120 x 40) allows for longer running gaits and is cushioned to provide protection against each impact on foot fall. The computer monitors time, distance, speed and calories. The auto stop key is present for safety reasons and the treadmill can be folded away after use to maximise your space.
Features -
* Motor - 1.0HP continuous DC (2.2HP peak)
* Speed - 0.6-8mph
* Incline - Manual elevation
* Console - Large LCD screen displaying speed, distance, time and calories burnt.
* Deck - Cushioned running deck to reduce impact, size 120cm x 40cm (L x W)
* Folds for easy storage
* Product weight: 50kg
* Maximum user weight: 16 stone / 100kg
* Auto stop key for safety
* Hand rail sensor/pulse reader
reduced from 250-150 delivered
Comments? Suggestions?
Only downside i can see is im on the top end of the max user weight, but lets be honest thats for running jogging impacts that really strain the motor, im betting a 20st fattie could walk on it all day
Features -
* Speed - 0.6-8mph
