Our best memory deal yet!
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
Memory prices have started to rise and dollar conversion rate is still poor but at OcUK we purchased the memory before increases and at good dollar rate so we can now bring you this mind bending crazy deal:-
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK)
OCZ PC2-6400 Platinum Revision 2 is the latest version of the Platinum DDR2-800 Series. The PC2-6400 Platinum Rev. 2 has been re-engineered to turn out heart-pounding 4-4-4 timings with flawless performance and stability and offer lower latencies than standard 800MHz DDR2 memory.
OCZ exclusively developed these modules for the extreme gamer and overclocker to give high-end DDR2 based systems that extra performance edge that is demanded by today’s hard core gamers and enthusiasts.
The new OCZ PC2-6400 Platinum Rev. 2 utilizes the latest OCZ heatspreader design. XTC (Xtreme Thermal Convection) Heatspreaders allow increased ventilation and heat dissipation due to an innovative honeycomb design providing more direct access to the actual memory ICs.
As part of the award winning OCZ Platinum DDR2 series, the PC2-6400 Platinum Rev. 2 is built with leading edge technology designed and qualified with special selection of premium components to maximize performance in even the most demanding computing environments. OCZ PC2-6400 products are 100% hand-tested to ensure compliance with stringent quality standards. In addition, each member of the OCZ Platinum family is backed by an industry-leading lifetime warranty, toll-free technical support and the exclusive EVP (Extended Voltage Protection) coverage.
With its ultra-fast performance, high quality and reliability, the OCZ PC2-6400 Platinum Revision 2 edition is a perfect memory upgrade for the latest CPU arrivials.
- 800MHz DDR2
- CL 4-4-4-15 (CAS-TRCD-TRP-TRAS)
- Platinum Mirrored XTC* Heatspreader
- OCZ Lifetime Warranty
- 1.9-2.0 Volts
- 240 Pin DIMM
- OCZ Enhanced Latency Technology
- 2.2V EVP**
Price: £21.99+VAT (£25.84 Inc. VAT)
BUY NOW!!
I think you will all agree this is an incredible price for such a high specification of memory with CAS 4-4-4-15 timings at 800MHz with good overclocking potential. Backed up by a lifetime warranty from OCZ! :)
Get your wallets out! :D :D :D
Cant believe how much this has dropped in price, I paid £116 for this around a year ago.
Going way way back (?11-12 years?) I remember paying £320 for 4 4MB SIMMs - and they were second hand - at the time that was quite a good deal! (And even further back I remember 1kB memory cards for eurocard racks!)
It would be even crazier if you offered free delivery :D
But still.. £25 for 2gb is flippin' brill.
Matthew
No time like the present, it would seem, to complement my other 2GB of this stuff. =)
Nice one, Gibbo!
Bargain. Already have 2 sets of this (one set is slightly different though - DFI certified)
First set cost £70, second set £35, now I can get it for £25 :eek:
Will likely be ordering some for a mate's pc in this next week.
Seen as your here, have AMD delayed the X2 till the 28th, or was it always the 28th, and the 23rd was just a rumour. :p
i've already posted this question but haven't got a answer. so heres it again.... can ocuk get some PC8500 @ 1.8v? which works with the Phenoms. e.g KVR1066D2N7, KVR1066D2N7K2, KVR1066D2N7, KVR1066D2N7K2
ive got 2 sticks of these, worked fine in my asus p5k , bought two more from ocuk, they wont work at all in the p5k, yet work fine in another pc.
Must be different types of memory.
Great price though
im not sure what why this tread is in graphics card section maybe gibo thinks they are graphics card ram rofl but yes they r cheap hope ddr3 will go down to
To grab as much attention as possible, its also in the memory section.
