Yep how people get 10k + out of them I do not know.
People just doing regular motorway driving etc I'd imagine.
After an afternoon of hard thrashing I'd be able to tell visually that they had worn a bit more.
Some of us cant rotate due to tyre size differences.![]()
. I only did it because it ment I got better life out of the fronts, when the outside edge started getting low I fitted them to the back.[TW]Fox;10956624 said:But you did drive it like your trousers were on fire![]()
Even just driving normal ish the Eagle F1's on the rear only ever lasted 6k ish.
Has anyone tried these?
My mate has them on his car and under full lock conditions at low speed you can hear them judder as the tyre rotates and half the V groove contacts the road ( Tread is Perpendicular to the tyre direction)
Reason I ask is that he is also haveing an issue with tyre wear on the outside of both front wheels. Half the tread is worn down to almost the indicators after only 5months (4k max.) of being on the car, thats without driving like a loon. It does seem to struggle for grip so I'm wondering if there's an alignment issue, even though tracking was fine.
He hates the tyres and blames them, but i certainly wouldnt expect them to be bad for grip (GSD-3)
[TW]Fox;10956374 said:A tyre wearing like that is surely down to underinflation/poor allignment?
.Outer edge tyre wear is either caused by too much toe out or positive camber. Both of these will cause a front wheel drive car to understeer more. It can also, potentialy be caused by driving hard and forcing the car to understeer a lot. If that's the case you need lessons on how to drive your front wheeled hot hatch properly.
[TW]Fox;10957374 said:You have an FWD car which wont understeer?
