[TW]Fox;10957440 said:Yes. Just suprised his doesn't, especially with the way he tells us he drives it
Never ever ever have I pushed my car to understeer. It will only understeer right on the limit of grip and then I simply lift off into a bit of oversteer. Yet the outside of both front tyres is bald wheras the inner edge and middle bit is fine. The car is standard and doesn't have positive camber, it could probably do with a bit of negative but sadly it isn't adjustable.
Do you know why a FWD car understeers?
[TW]Fox;10957374 said:You have an FWD car which wont understeer?
[TW]Fox;10957582 said:They are BMW wheels and are the standard tyre size for an E39 Sport on 18's.
Understeer is not just a handling characteristic of FWD cars. A RWD and 4WD car can understeer too. Likewise, any car could oversteer too.
It all depends on how the car is set up and how it's driven.
i have the same outer edge wearing thing, havent kdsd it, however the tyre pressures are spot on.
What tyres? I assume a LCR too?
