The OP did write 32"+I would expect the demand for such technology in a 32" is pretty low? I mean 1080p at 32" is overkill on it's own, you'd have to fit <2ft away. Cramming in 24p support and 100hz scanning means more expensive internals... can't see the point, would surprise me if there were many/any. Go bigger![]()
If you want it to be doing 100hz to a 50hz signal all it is doing is adding a black frame to try and trick you eyes into not seeing the motion blur from LCD pixel refresh but most of the time it will make the image worse.
My mate has been getting sound/video out sync with his new Panasonic 42pz70 TVThe main reason im looking at 24p/100hz stuff is because i keep getting sound/video sync problems. I was thinking that its possibly my current TV thats the culprit.
So as im thinking of upgrading my telly to a bigger model, i might as well get some decent features on it..
