- 26 Aug 2003
I'm after a cheap flash to give me a bit of scope for portrait stuff, but to be honest I'm not prepared to spend a lot just right now.
With voucher codes and the sale they're having, I can get the Sigma EF-500 DG St for £63, and the Sigma EF-500 DG SUPER for £91. Are they worth it?
I've read mixed reviews, but they seem to be a fairly solid budget flash, and the prices above are both over £50 cheaper than normal.
What do you guys reckon? I'm thinking it would be perfect for a budget flash to learn on, which could then be 'relegated' to a second flash if I decided one to splash out a bit more on an SB-600 or similar (which I just can't afford right now, or for a while).
Otherwise, any recommendations for similarly cheap flashguns? I use a D40, by the way. Any advice appreciated!
