crossfire 3870's and the abit ip35-pro
21 Jan 2003
Northamptonshire
Just a quick one lads.
When in crossfire should i be hooking up the additional atx4p1 connector on the abit ip-35pro?
Its says in the manual for additonal power for pci-e graphics cards and such.
But nothing else?
Also the instructions that came with the cards doesnt say to lol.
Cheers
I've improved on my score in the 3DMark06 thread, I just a) can't be bothered updating anymore, and b) have more pressing issues atm ;)
Thx for reply
In my manual it says something abit diffrent:confused:
This connector provides an auxiliary power source for devices added on PCI Express slots
I guess i will just have to give it a go:)
Is this required if just using one pci-e card? Having a clean up inside the case and removing unnessecary cables. Just unplugged it and PC's working fine, but havent tested a game yet. Im guessing its just for a second pci-e card as my 4870 has 2 power inputs.
Yes i have read all the posts thanks, but i just wanted to clarify that its not essential if not using crossfire.
Its easy to make assumptions, but i want to be sure as im going to be drilling my case, so dont want to miss a hole that may be needed and nor do i want to make a hole if its not.
