G92 with Black PCB
14 Aug 2006
Land of Dragons
As above, need one for a new build.
Any of the new boards with a black PCB ?
Think I have seen the older GTX with a black PCB
TY for info/links :)
Meh, it's still the better card unless he's after a GT in which case I don't think there are any with a black PCB.
Really after a G92 GTS if their Available with a black PCB, already have a GT, It's the black PCB that is the crucial item.
So the only one so far is the old GTX.
Any new ATI with Black PCB, unlikely I know. (hate red boards)
Define "better"?
I thought the G92 GTS beats the GTX in most games, it's cheaper and doesn't require two power connectors and doesn't require cutting your case apart to get it to fit (in a lot of cases)
Could always wait for the GeForce 9800 GX2, its got a black PCB.;)
http://www.techpowerup.com/?50961
Cheers for the pic, but that looks as long as the original GTX, hoping for something like the length of the G92.
Find it hard to believe, not one manufacturer has not asked for a black PCB on the G92's.
They've made an error there, as thats the 8800 GS, not the GT, you can tell by the cooler. :p
Their GT's are black PCB's as well though, but if i had that cooler there on my GT id be very worried. :D
Im guessing that big hole is a carrying handle due to it being so big/heavy? :p
GT and GS coolers are interchangeable. Same PCB except there're two less memory chips on the GS.
QUOTE=LoadsaMoney;11009920]
Their GT's are black PCB's as well though, but if i had that cooler there on my GT id be very worried. :D[/QUOTE]
See if I can unscramble that :confused::confused:, are you saying they make a 8800GT with a black PCB, or they make the old GTS with a Black PCB ?:D
Not fussed on the cooler, as it's going under a nice black and chrome water block.
Cant find a black G92 board anywhere :(
:confused::confused::confused: He did just say their GT's have black PCB's...
