Ok, so I have just bought myself a nice pair of monitor audio RS6 speakers. Now I looking into wiring them up. It suggests in the manual that I bi-wire them, which as far as I understand it is running two pairs of wires from one pair of terminals on the amp to the speaker.
Now personally I can't see the benefit of this? The speakers have a bridge across the terminals on the back so what difference would I get from running a whole new set of cables except for the small amount of loss across that short bridge?
Can someone enlighten me as whether it is worthwhile to do and what cable setup I should go for.
My options so far seem to be:
Single strand cable stereo plugged into a single terminal with the bridge across to the other.
Bi-wire cable plugged into both terminals
Single strand plugged into a terminal and then looped into the next instead of using the bridge.
Any advice greatly appreciated.
Or at least three separate stereo amps for the low, mids, highs.
. One amp down, 2 to go! Speakers being made by me too. I'll be sure to sure to show you when (if) it's finished
