Im talking about the X2, not crossfired 3870's, if the game is not crossfire supported in the drivers, then the 3870 X2 will run as a single 3870, as it will only use one of its cores, and it will be an expensive one, as the X2 is £300 on here, that means your playing that game on a £300 3870 until ATi add the crossfire support for that game into the drivers, so you can use both your cores.![]()
Basically you have not got a clue about what has to be implemented for a game to run on this card or not.
Please point me to a link that has the 3870x2 running at single 3870 card speed on a game while 2x 3870 are spanking away.
. Thanks for the info
