What worries me is that the pci-e bridge chip on the stock ATI card actually comes into contact with the heatsink (giving me the assumption that it would need some form of cooling) yet on this powercolor card it doesn't appear to be cooled at all.
Another worry is that the box shows the zerotherm cooler still lol
EDIT: Just noticed the link states that it doesn't need cooling?!
Also it seems VERY wide (like X1950pro dual wide)
I think "very wide" is just an illusion, it's no way near as wide as the 1950 Pro Dual, it looks about 10mm wider than a 2900 (using my 2900 as a reference and the photo of that shorter X2 to work out its rough dimensions)![]()
Look at the bottom image. It looks a good inch wider than the backing plate.
from the bottom image, looks like the card is about 150mm wideHaving the card extra wide isn't a problem I don't think. I think near enough anyone would happily have a wider card if it lost a few cm in length.
Jesus that cant be right surely, its well loud, 83dba is that, wtf, ear bleeder!!!![]()
I like both takes on the alternative cooling! The shorter PCB on the Powercolour is great news for people using smaller cases and the 2xPCI-E 6Pin connections is great too!Jesus that cant be right surely, its well loud, 83dba is that, wtf, ear bleeder!!!![]()
mic held 2 cm from board, why don't these sites use the standard 1m dagnamit!!
