Is the 2900pro that good?
It is when you don't use AA. Easily double the power but not at stock, I had to OC to get the true performance out of the card. You can use AA with some titles but you have to play around with different AA modes to get the best performance. Without AA the card is really fast. I wouldn't recommend anyone to get one though. The power draw is more than the new X2 3870 and the fan is really loud when cranked up. Single 3870XT would be a lot better but then you are sitting in 8800GT territory which is the faster card and can handle AA a lot better but not at the biggest resolutions. I'd only recommend the X2 3870 for big resolution gamers unless AA isn't important then you could easily get the single 3870 and have some great gaming experiences. If AA is needed then a single Nvidia card is top dog in that regard.
I only bought the GTX so I could run AA/AF without the hit. Without AA the AMD cards run very well and the more immersed you get the less you look for jaggies. I didn't notice much improvement moving to the GTX other than AA.
). My C2D @ 2.66 can only manage 32.95fps on high @ 1280*1024!
