Gonna sound a total retard - but what is it? a 200-500MM 2.0 or a 400-1000MM 5.6? Tad confused by the spiel at the bottom.
Is it 200-500 2.8 then it can do the rest at 5.6?
Rich
ooops ^ too late
Rich
Unlikely I thinkTalking of minimum focusing distance, the 200-500mm f2.8 has one listed as 150cm which seems pretty damn good if that all the way up to 500mm. Whack the converter on and you would have a seriously oversized macro lens.![]()
so, we've got the Bigma and the Sigmonster. what will this be called? Sigzilla?
based on its looks..
Sigzooka
turns out its already called Sigzilla.
The zoom ring and focus ring are motorized :/
RRP £17k
No price on that yet : http://www.sigma-imaging-uk.com/lenses/telezoom/150-500mm.htmAnyone found out the RRP of the 150-500?
I'd so buy one if it had 100-400 IQ!
Exactly !But its f6.3 on the long end.
Exactly !
It'll be sharper than the Bigma (50-500) 3.3x vs 10x zoom but F6.3 is slooooooooow.
But what is there thats a zoom that is 500mm and not stupidly expensive?
Nothing, well that was difficult :/
