Qloud Itunes Plugin
13 Dec 2006
Hi,
For some daft reason I installed the Qloud plugin for the stupid facebook app (laugh if you wish) and now it doesn't even work properly so I am trying to uninstall it.
The instructions say to go to Libary > then Itunes > and then to the plugin bit and remove it from there. However there is nothing in that folder and I cant find it anywhere it is driving me insane.
Any ideas?
Have you tried
xxx > Library > iTunes > Plugin ?
Where xxx is whatever you called your user name.
Sometimes when you install stuff, if it's only for your username, it'll store it in there instead of the root's library.
Edit: I need to type faster!
Have you tried
Yes you do, lots faster.
While you were typing, and I was doing mine I was able to check both locations, one had a plugin in, the other did not. :p
OT: I don't get all the rave about Quicksilver tbh. :o
I OFFICIALLY LOVE YOU TWO!!!! (WotDa more though since he got there first hehe)
Thank-You, I'm still a bit new to all of this and it was quite annoying me. Don't even know why i installed that carp in the first place.
