- 9 May 2007
chi@chi-desktop:~$ glxinfo
name of display: :0.0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer,
GLX_OML_swap_method, GLX_SGI_make_current_read, GLX_SGI_swap_control,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_visual_select_group
client glx vendor string: SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_allocate_memory,
GLX_MESA_copy_sub_buffer, GLX_MESA_swap_control,
GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_OML_sync_control,
GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_EXT_texture_from_pixmap
GLX version: 1.2
GLX extensions:
GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_SGI_make_current_read,
GLX_SGI_swap_control, GLX_SGI_video_sync, GLX_SGIS_multisample,
OpenGL vendor string: Tungsten Graphics, Inc
OpenGL renderer string: Mesa DRI Intel(R) 945GM 20061017 x86/MMX/SSE2
OpenGL version string: 1.3 Mesa 7.0.1
OpenGL extensions:
GL_ARB_depth_texture, GL_ARB_fragment_program, GL_ARB_imaging,
GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_point_parameters,
GL_ARB_shadow, GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
GL_ARB_texture_env_dot3, GL_ARB_texture_mirrored_repeat,
GL_ARB_texture_rectangle, GL_ARB_transpose_matrix,
GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_window_pos,
GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_clip_volume_hint,
GL_EXT_cull_vertex, GL_EXT_compiled_vertex_array, GL_EXT_convolution,
GL_EXT_copy_texture, GL_EXT_draw_range_elements, GL_EXT_fog_coord,
GL_EXT_histogram, GL_EXT_multi_draw_arrays, GL_EXT_packed_pixels,
GL_EXT_point_parameters, GL_EXT_polygon_offset, GL_EXT_rescale_normal,
GL_EXT_secondary_color, GL_EXT_separate_specular_color,
GL_EXT_shadow_funcs, GL_EXT_stencil_wrap, GL_EXT_subtexture,
GL_EXT_texture, GL_EXT_texture3D, GL_EXT_texture_edge_clamp,
GL_EXT_texture_env_add, GL_EXT_texture_env_combine,
GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_lod_bias, GL_EXT_texture_object, GL_EXT_texture_rectangle,
GL_EXT_vertex_array, GL_3DFX_texture_compression_FXT1,
GL_APPLE_client_storage, GL_APPLE_packed_pixels,
GL_ATI_blend_equation_separate, GL_IBM_rasterpos_clip,
GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate,
GL_MESA_pack_invert, GL_MESA_ycbcr_texture, GL_MESA_window_pos,
GL_NV_blend_square, GL_NV_light_max_exponent, GL_NV_texture_rectangle,
GL_NV_texgen_reflection, GL_NV_vertex_program, GL_NV_vertex_program1_1,
GL_OES_read_format, GL_SGI_color_matrix, GL_SGI_color_table,
GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SGIX_depth_texture,
GL_SUN_multi_draw_arrays
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x23 24 tc 0 32 0 r y . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x24 24 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x25 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x26 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x27 24 tc 0 32 0 r y . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x28 24 tc 0 32 0 r . . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x29 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x2a 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x2b 24 dc 0 32 0 r y . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x2c 24 dc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x2d 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x2e 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x2f 24 dc 0 32 0 r y . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x30 24 dc 0 32 0 r . . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x31 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x32 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x5b 32 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 Ncon
GLX version: 1.2
GLX extensions:
OpenGL extensions:
in animations i can set thing to close in a certain way
now when i go on i can just click on a theme and it will come up immediately
