I just bought this from ocuk for £100 delivered.
OCZ 4GB (2x2GB) PC2-6400C4 800MHz ReaperX HPC Enhanced Bandwidth Edition Dual Channel DDR2 (OCZ2RPX800EB4GK) (its 4-4-3-15)
I have it overclocked to 1080mhz @ 5-5-5-18 2.2v at the moment, using 5:6 divider on my Abit IP35-Pro, my fsb is 450*8 so ram is a tasty 1080mhz. I tried 456mhz @ 1:1 4-4-3-15 2.2v but unfort it failed in memtest after a few mins as i ran my team xtreem 2gb ram @ 456*8 (3.65ghz) 4-4-3-4 2.2v.
UPDATE: I've just tried it with 1:1.25 divider (1125mhz) with 2.35v but that failed, i dont really wanna put anymore voltage through it as i'm a bit chicken! So my next step is to lower timings a little to find its lowest timings @ 1080mhz.
UPDATE 2: Looks like 5-5-5-12 is my limit @ 1080mhz, im very happy with this
In reviews it gets between 1100-1140mhz usually for 5-5-5 with 2.2v.
Photo:
Btw the ram is only a little bit warm with 2.2gb due to those great heatsinks!
Also you can only use 2 sticks as the heatsinks are to wide to let you use 4 sticks of ram on your motherboard, but by the time people need 8gb ram there will be ddr4 out!
Reviews: http://www.ocztechnology.com/produc...aperx_hpc_enhanced_bandwidth_4gb_dual_channel
Photo:
