Nice, Ubuntu just wiped out my RAID array...
19 Dec 2006
UK
So, I decided I'd have a play with Ubuntu and grabbed the iso image, burned it and threw it in my main pc, it then went on to destroy my RAID0 array. First I knew of it was when it listed the individual drives in the partitioning section during setup, goodbye everything...
Glad I keep 99% of my junk on a backup drive :o
Be warned.
When you installed Ubuntu how did you do it? Manually partitioning and telling it to install to the disk outside the RAID?
Well I made the point because it might be that he just lost the bootloader and not the RAID array itself. In which case it can be recovered by booting from the Vista install disc, opening up a cmd prompt, and then Bootrec/fixboot and Bootrec/fixmbr commands.
This was what I was atttempting, it got as far as displaying the list of drives and had both my raided drives showing, at which point I became concerned and exitied the installer to find it had destroyed the array.
No, the array is gone.
The Ubuntu installer doesn't touch the disks until you proceed to setup which you do on the screen after the disk partition tool (the screen that lists everything you have chosen to do).
Oh look a working array...
I'll select the dvd-rom that the Ubuntu disc is in to boot from...
Install in text mode sounds good to me...
English please...
yup, I'm in the UK...
Nah, I'll choose that...
Yes, I have a US Keyboard...
Yes, it's US English...
Loading modules and DHCP and stuff...
Ubuntu sounds good to me...
Manual please...
Ho hum... what's this, the 80GB drive I want to install Ubuntu on and those two 164.7GB drives sure look like the two that should be in my array...
Hmmm... yes that one there... think I'll quit out of this...
Yup, abort please...
Yes please...
What was that you say? it doesn't touch the array?
oooops... lets try a reboot...
Nope, it's destroyed the array...
and you don't think at this stage you should have selected "undo changes to partitions"?
Different partitioning tools work differently (oddly enough). If you compare this to the Windows installer - you don't get a "undo changes" option - once you select the option, it gives you a warning saying that the changes are irreversible and that's it.
Personally, if I had noticed that my raid array looked screwed, I would have clicked every "undo" button until it was fixed.
Also, I would have backups.
What changes? it hasn't been asked to make any changes at this point, all it's done is show the list of available drives and partitions and in fact jumped past that menu option to the <Go Back> option as there was nothing to undo.
True, but windows at least warns you...
From my very first post...
I'm effectively defending a distro that I have never used and likely never will use.
I'm sorry to hear that you've had a bad experience with it, but almost always when things like this crop up, it's user error.
Ive tried replicating it with silicon ATA software RAID array 2x200GB drives and it changed nothing :confused:
Instead of just moaning about it, report the problem to help improve support or go search the ubuntu help to see if anyone else as had it.
RAID 0 is very intolerant anyway and shouldnt be relied upon, no doubt why you have back ups.
Different hardware = different issues.
Who's moaning?
Doesn't matter wether it's RAID 0, 1, 5 or JBOD, backups are essential period.
