I'm going to slipstream SP1, then do a fresh install using my newly created Vista SP1 DVD.
Normally you just copy the contents of your install media onto your hard drive, and run the service pack install from the command line with a switch to apply it to the folder you just copied the media to, then burn that lot back to a DVD with the boot image copied off the original disc.
Edit: Often programs like nLite / vLite will do it as well, which is easier.
Is it just RC1 tomorrow?
Wonder if it will install onto my version with a beta of SP1, I hope so!!
