Nokia 95 and nokia 95 8 black
No idea I'm afraid. I don't blame you for avoiding Voda. For what it's worth I've got the vanilla N95 on Three and I'm very happy with it (my friend with the 8GB is equally happy, especially since he gets to lord it over me).
only thing about 3 though is they force that 15 quid video package on you even if you don't want it :(
They are required to by law - they can't give you a free phone up front and charge you per month for it alongside a contract (as it was explained to me by a friend who was working Three retail). If it's any consolation, you can pick up £50 or so Quidco and £30 if you get someone already on Three to refer you.
So are you saying you have to take the £15 video thingy or not :confused:
N95 8Gb - Better battery, bigger screen, 8Gb memory internal, native Flash support on the browser (ie full youtube.com), better build quality and a lot better looking.
N95 - Has a micro SD slot (ie expandable memory, whereas the N95 8Gb cant do this).
I'd go for thr N95 8Gb every time, its just a far better package.
Also anyone got this phone on vodaphone does there software still cripple it ??
I have it. The software is a little dated, being v11 when they now have v15 and is v20 out?
Runs fine tbh, it doesn't crash (too much - I think DivX player was causing my crashing on music player as it hasn't done so since the uninstall this evening). I also got rid of all the demo games and unwanted stuff.
Aside from sat-nav software (Garmin, not Nokia Maps) and aforementioned music player, I've only had one crash in the 2 weeks I've owned it using the phone normally i.e. everyday use.
I absolutely love the phone.
You do. You are effectively paying £15 a month for the phone, but they are required by law (if I'm told correctly) to give you something on a monthly basis in return for the monthly charge, hence the video minutes.
Can you use your ownmp3's for ringtones etc
anyone else confirm this ?
Guy in shop said 16 hours but I was under the belief that this wasn't needed with new li on batteries
the new batteries dont need no "extra" charge and dont need to be used til the very end before recharging for best life
