- 28 Sep 2003
- Leamington Spa
Hi there, I must admit I'm a bit of practice messing around with ram timings, but I'm having some real issues here. A while back, a got 2 sticks of ocz pc2 6400:
http://www.overclockers.co.uk/showproduct.php?prodid=MY-072-OC
This worked great, after a bit of messing in the bios to get the correct timings. Today I've just installed xp 64 and 2 more sticks. Things went bad fast, corruption all over the shop, so I fired up mem-test. Sure enough tonnes of errors. So I take out the 2 new sticks, it works fine. Now I *switch* both sticks for my new ones, and they both work fine.
If I put in 1 more (3GB) loads of errors, and 4GB, loads of errors. I'm assuming somewhere I've made a grave mistake in terms of voltage/speeds.
I'm using an abit ip35 (*not* the pro, nor the 'e' version), could someone please suggest what settings I should try?
