I've had a ram mount made by this guy: http://www.telferizer.com/ and it arrived this morning.
It fits through the headstock hole and bolts in place with a plate underneath via a locking nut. I added a second nut just for security though.
Mounted to the bike (You can see where the old mount went which was less than ideal)
More pics
Should be good for a bit of touring over the summer.
More pics
