That's quite an exaggeration; I'm running Vista with 2GB and gaming is absolutely fine, and that's running at decent resolutions (often 1680x1050) and high detail levels.
That's not to say 4GB isn't going to be better still, but 2GB certainly isn't only adequate for "light usage".
if i was talking about minimum required i could have said 512mb, but i stated the OS sweet spot which IS 4gb. gaming with 2gb in Vista is like 1gb under XP ...not enjoyable.
snip
To use readyboost do you need to format the flash drive?
I have a corsair flash voyager which I may try it on (presuming the drive will work as a readyboosy device).
maybe because i had 2gb when Vista was first rels'd and everything was relatively average then.
with a fast quad and 4gb i do like to keep things running while i game so i probably pull another 500-600mb in apps that i don't need to.
with the price of DDR2 i just don't see the reason not to run 4gb.
You've only just finished rolling out XP company-wide?.![]()
One thing - if you have a readyboost device connected to a USB hub do you have to remove it before rebooting, or just reboot as normal and let windows deal with it?
I'm getting 15 MB/sec copying from one HD to another. Oh dear still not fixed. Also slowing down Windows itself, it paused whilst copying this paragraph.
Fine in XP.
Fine in XP.
Fine in XP.
Vista SP1 does not solve many problems
Invents some new ones
By Nick Farrell: Friday, 08 February 2008, 9:30 AM
REVIEWERS of Microsoft's SP1 service pack for Vista have discovered that the upgrade means that files will copy nine per cent faster.
However, according to the likes of PC World, SP1 comes with a few bugs of its own.
The Vole claims real improvements to copying, compressing, and extracting files, better boot and power down times, improved network performance, and more.
However installation in PC World's tests, took 27 minutes and three reboots. Most of the time was taken up by Vista having a little think while it 'prepared the configuration'.
Start-up and shut down times remained the same. It seems the nine per cent improvement in file copying times was the only real difference.
It is unlikely that many people will notice a difference between SP1 and an unpatched system. It is also likely that companies that have held off from upgrading from XP will not bother as it hardly seems to be worth the time, money or heartache. µ
