My opinions on Vista SP1, 8 months later..
Nothing wrong with Vista for me once I got 4GB Ram + a 32MB cache HD. It now runs like a rocket and is much better than XP for me in everyway. Obviously going from XP it is a bit of a shock and some things are not working as well as they should be. Give it a bit more time and it will become a firm favorite.
It needs a bit of tweaking and is very complex to get the most out of your hardware but even without SP1 I am still getting incredible HD to HD transfer speeds. Took under 3 mins to copy approx 12GB of data (lots of little files as well) from a Samsung 750GB 32MB cache to a Samsung 250GB 8MB cache.
A lot of Vista's bad rep is due to people not understanding what it is doing and why and tweaking to get the most out of their system.
The best perfromance tweaks I have discovered (after using several different HD's are as follows):
1: Get a 32Mb cache HD. Even a Raptor 150 I found was not good enough for Vista. My new Samsung is much snappier and also silent. This alone has given me the biggest performance boost of all.
2: 2GB Ram min. 4GB is better but even then it only ever uses 1.5GB max.
3: Disable or tweak Windows Defender.
4: Go into Task Scheduler and disable some of the features you do not require.
5: Disable Disk Indexing.
6: Disable & delete both the pagefile & hibernation file.
I think MS dropped the ball in that Vista straight out of the box is designed to go on either Laptops/Desktops/Media Centres and does not offer a custom install which would say remove features which may not be required if you had 3 choices for hardware types.
Hello barnettgs, please link me to a half decent article that has reasonable arguments saying that Windows Vista is pants? Once again, what is it that you don't like about Windows Vista and/or what do you think makes it such a bad Operating System? :)
i dont like the fact that my transfer speeds are atrocious, especially when people are telling me there's nothing wrong with vista
Yeah it's like talking to religious zealots. I've done the tweaks, updates, disable defender, latest drivers, disable remote differenterial...still dog slow.
I had to copy files from HD to HD, in Vista it was driving me nuts- so just booted with Ubuntu Live CD and the same copying process was twice as quick.
Sorted in SP1.....
Which isn't out yet? Just as a Beta..and how long has Vista been out?
Inquirer is just reporting on the SP1 test results from PC World - http://www.pcworld.com/article/id,142233/article.html
You're in the minority who think Vista is good, when it isn't.
Trying not to rise too much to your poor attempt at trolling, and discounting people who think that Vista is bad because it doesn't let you do the stupid things that XP did but shouldn't, what's the problem with Vista?
MS are being cautious to stop people rush installing and breaking stuff. If that happened you would be on here complaining they rushed it out without fulling testing it or making sure driver wouldn't cause issues. It's not a beta anymore it's RTM'ed and it's with hardware vendors and partners to make sure it works with there products.
I missed the day when they said how long an OS should be out before it's updated. If you look at XP it's been out 7 years and has had 2 service packs that must be well overdue.
Exactly why I can't be bothered to explain every time I say Vista is rubbish.
Dolph, don't need to take what I've said personally. It's not you, it's the Vista that sucks! :p
I'm not sure the zealotry is on the pro-vista side, they tend to back up their arguments far more. You complain about file transfer speeds and imply it effects everyone, it does not. I have no problem with transfer speeds in vista apart from across the network, which is addressed in SP1.
How many bug fixes did XP SP1 fix and how many were far more major than those in vista?
Vista was launched on Jan 30th 2007. How many people here were using XP a year after launch, and how many were naysaying it? How many were complaining of issues before XP SP1, and how many were more of a problem than those with vista?
I don't understand Vista haters, Vista isn't bad at all and comparing it with XP is silly, why? XP's had a fair good life span and Vista has only just had it's first birthday. You cannot tell me that XP, when first released was the best thing ever because it had as many problems as Vista does.
Without any explaintion, it's impossible to take your comments seriously. This is further compounded by most of those speaking out with similar views to yourself giving views that don't stand up to evidence or show fundamental misunderstandings in the way things work.
Without an explaination, it's simply going to be assumed that you are in with the above group...
What a laugh.
I've just been dealing with 3 different people who wanted machines from the Purple Shirts and they all came round with printouts of machines that had 512 meg of RAM :eek:
You have to pay £499 before you get your first Vista machine with 2 gig in it.
Lets all take our memory out down to 512 and see what results we get.
Now go do your homework.
Copy from SP1 machines to SP1 machines, or from machines using older operating systems? If the latter, why blame vista?
Well posted from the SP1 but I think it's also relervant to this thread:-
1 x WHS
1 x Vista Ultimate (No SP1)
1 x Vista Ultimate (SP1)
The SP1 build is:-
6001.longhorn_rtm.080118-1840
Initiated from Vista
Drag-n-drop of a file from Vista Ultimate (No SP1) to WHS
Drag-n-drop of a file from Vista Ultimate (No SP1) to Vista Ultimate (With SP1)
Drag-n-drop of a file from WHS to Vista Ultimate (With SP1)
Drag-n-drop of a file from WHS to Vista Ultimate (No SP1)
Initiated from WHS
Drag-n-drop of a file from WHS tp Vista Ultimate (No SP1)
I'm not sure we can claim the slow copy is fixed if it only works from Vista SP1 to Vista SP1 machines!
Apart from this one issue for me Vista is fine
When XP was released, it took at least 2 years for the bitching and moaning (in some cases from the same long term posters). The amount of bitching about compatibility (XP was far worse than vista in this regard), cartoony interface and too much handholding was nuts at the time, as were complaints about performance and so on, and so on.
