Abit IP35 Pro post code 8.7. no boot!
Man of Honour
8 Nov 2007
Outer Space
Anyone have any tips or experience with this error code?
It locks on 8.7. the instant I press the power button, all fans running.
1 stick memory, cpu, GFX card, h/d only connected.
Its driving me mad! :mad::confused:
(Abit IP35 Pro, Q6600, 1gig Crucial Ballistix PC2-8500, Nvidia 8800GTS (G92), Tagan BZ 900w, Seagate 250gig H/D)
Any help would be greatly appreciated :)
To be honest I've found the IP35 Pro abit unreliable (pun intended) , I've had to RMA two of them:-
1. LAN ports didn't work
2. Wouldn't recognise any IDE DVD/CD drives
Hi guys,
Sorry for late reply, I butchered my old pc to try other parts late last night and it still didnt work, so I just watched some TV and went to bed as I was getting too annoyed!
Have reset CMOS with and without removing battery, tried another GFX card & other memory, and this morning have tried the board out of the case and its still the same, 8.7.!
abit online help suggests making sure the 4-8 12v plug is in place and if it is then to replace the PSU? anyone think thats what it could be, the PSU?
@ Smirnoff, the cpu is in place, is there a chance the cpu is dead? is a totally brand new Q6600 Quad!
Should I buy another PSU and return this one?
Thanks for all your help so far :)
What HSF are you using, stupid suggestion but have you tried loosening it a bit if it's one of these screw down types?
I am using a Thermalright Ultima 90 with a 120mm Noctua fan.
I tried loosening the screws alittle but no difference.
Not sure what to think, some are saying its likely a faulty PSU, others are saying mobo?
That's unlucky. I've built perhaps a couple hundred systems with this board and I don't think any have failed to work.
Just tried my current PSU from my old Dell Pc and it does the same thing so I am assuming its the mobo.
Also just had the Tagan PSU tested at a local PC shop and he seems to think the PSU is all ok.
@ Dr.Sarf, How do you rate the Asus PK5 Premium 'black pearl' against the IP35 Pro? Is it worth me changing mobo?
